how to add command in SE App menu?
Hello!
My name is Andrey and I'm developing addin for SolidEdge ST5. It would be great to know how I can add a new command bar in SE App menu. So could you tell me please if there a possibility to add items in Application menu through SE API?
Thank you,
Andrey.
3 REPLIES 3
Re: how to add command in SE App menu?
Andrey,
Everything you're looking for can be found on solidedgesamples.codeplex.com. Download the latest release and extract the .zip. Look in the following paths depending on your programming language.
.\solidedgesamples.codeplex.com\cs\AddIns\AddInDemo.sln
.\solidedgesamples.codeplex.com\vb\AddIns\AddInDemo.sln
Let me know if you still have questions.
Jason Newell
Solutions Architect
www.jasonnewell.net
Sorry, I explained incorrectly.
Is it possible to add my menu in Main Menu SE App? And how I can do it?Безымянный.png
I'm fairly certain that we used to be able to do that before Solid Edge moved to a ribbon UI but I'm unsure if we can still do it. I'll will look into it and see what I can come up with and let you know.
Jason Newell
Solutions Architect
www.jasonnewell.net
