how to change face style, or assign special color to part?
i use vb.net. the code is like this:
objApplication =GetObject(, "SolidEdge.Application")
objDocument = objApplication.ActiveDocument
objFaceStyle = objDocument.Properties
objFaceStyle.Item("MechanicalModeling").Item("Face Style").Value = "Green"
but it can't change. how can i do?
Posted by: Ben chen
Post date: 6/20/2011 2:10:38 AM
RE: how to change face style, or assign special color to part?
In SE 18 works this:
for faces...
Set ObjModel = ObjPartDoc.Models(1)
Set ObjBody = ObjModel.Body
Set ObjFaces = ObjBody.Faces(igQueryAll)
ObjFaces.Item(30).Style = ObjPartDoc.FaceStyles("steel")
for whole body...
ObjBody.Style = ObjPartDoc.FaceStyles(Color)
Also you can assign material from material table (material has colour)
Call ObjMattable.ApplyMaterial(ObjPartDoc, MatTabName)
Posted by: Jiri Marek
Post date: 6/28/2011 7:37:16 PM
thank you
Posted by: Ben chen
Post date: 6/29/2011 2:17:36 AM
