how to count all sheets in the drawing document?
Hello!
I have a question - how to count all sheets in the drawing through C#? Is it possible to do that? I didn't find any function in API.
Thank you,
Andrey.
4 REPLIES 4
Re: how to count all sheets in the drawing document?
Samples for Solid Edge on CodePlex is a great source of examples.
Here are the directly source code links from GitHub.
ReportSheets.cs
ReportSections.cs
Jason Newell
Solutions Architect
www.jasonnewell.net
Hello Andrey,
If you run Jason's examples, you will note there are three sections i.e. groups of sheets:
1. Working,
2. Background,
3. 2D Model.
These are depicted as below:
Sheet 1 - 4 are the working sheets.
You can enable or make visible the blue sheets by right-clicking any of the working sheets and selecting Background from the context menu. Same for hiding them.
To list all above sheets at once:
SolidEdgeFramework.Application oApp = (SolidEdgeFramework.Application)Marshal.GetActiveObject("SolidEdge.Application");
SolidEdgeDraft.DraftDocument oDoc = (SolidEdgeDraft.DraftDocument)oApp.ActiveDocument; for (int i = 1; i <= oDoc.Sheets.Count; i++){ Console.WriteLine(oDoc.Sheets.Item(i).Name); }
Console.WriteLine(oDoc.Sheets.Count);
On the last line is the answer to your query - how to count all sheets.
This will return 9 which includes the 2D Model, Working and Background sheets.
- Tushar Suradkar
http://surfandcode.blogspot.in
Thank you! Your answer helped me a lot, but I have a new question - how to filter sheets by groups? For example, I want to show only working sheets.
Frankly, my knowledge of the SE API is still building, and here is all I could pull together:
SolidEdgeDraft.Sections oSections = oDoc.Sections;
oSections.WorkingSection.Activate();
oSections.WorkingSection.Deactivate();
oSections.BackgroundSection.Activate();
oSections.BackgroundSection.Deactivate();
Pick what works best for you.
BR,
Tushar Suradkar
