how to create .igs document from assembly model.
[left]how to create .igs document from assembly model.i want to create assembly documents igs file by using vb.net in solidedge[/left]
Posted by: Yogesh Shinde
Post date: 5/26/2012 6:23:08 AM
Re: how to create .igs document from assembly model.
Hi Yogesh,
You can use object.SaveAs(NewName)
Object - Required. The object to which the method applies.(document)
NewName - Required String. Specifies the name of the saved file.
Hope this will works for u.
Posted by: sandip
Post date: 6/18/2012 8:36:17 AM
