how to edit hole object from a model
hi everybody,
i want to access holedata and hole object from model.
The problem is that i get objHoles.Count =1. And with this i can access third hole in hole collection where i actually want to access first hole.
When i use HoleDataCollection sount =3
Can anyone tell me why this is happening. Am using SE-19
 i used following procedure......
objHoles As SolidEdgePart.Holes = objDoc.Models.Item(1).Holes
"& this code to get hole count"
Dim objHDColl As SolidEdgePart.HoleDataCollection
 objHDColl = objDoc.HoleDataCollection
Dim holeData(holeCount - 1) As HoleData
For j AsInteger = 1 To holeCount
holeData(j - 1) = objHDColl.Item(holeCount)
 Next
MsgBox(objHoles.Count)Dim holeCount AsInteger = objHDColl.Count
"i used this code to get hole object"
Dim
Posted by: makarand kulkarni
Post date: 9/21/2009 7:15:54 PM
