how to get object below bundle node in Solid edge ?
hello,
I'm using API to report harness objects in Solid Edge.
I'm getting the list of wires , cables and bundle but I'm not able to get cable or wire or bundle below the bundle node.
Any help please..
Amani
Re: how to get object below bundle node in Solid edge ?
I dont think there is any API available to get the wires/cables from a bundle. Can you please file an IR for this?
Kaustubh
I have already did so...
Thank you
Amani
