how to get view from draft document
Hello!
I have problem - I don't understand how to get view from draft document to use components. For example, I have draft document of assembly. I need to get components of this assembly, which showed on draft document.
Re: how to get view from draft document
You can use Spy for Solid Edge to access to the description of what you have in your draft document (thanks Jason) .
You can access to the component of an assembly in your draft for the draft Document or the drawing view.
From draft document : ActiveDocument.ModelLinks.Item(1)
Item number depending of how many file are present in the draft document.
Spy for SE
Romuald BERTIN
Hello tucha_te, rbertin has shown you the right direction with getting the model links to the assembly model of the view.
To answer your question as in "- I don't understand how to get view from draft document...",
the following lines will step wise take you to the assembly ocurrences beginning with the view in the Draft sheet:
Dim oApp As SolidEdgeFramework.Application = Marshal.GetActiveObject("SolidEdge.Application")
Dim oDoc As SolidEdgeDraft.DraftDocument = oApp.ActiveDocument
Dim oSheet As SolidEdgeDraft.Sheet = oDoc.ActiveSheet
Dim oView As DrawingView = oSheet.DrawingViews.Item(1)
Dim oModelLink As ModelLink = oView.ModelLink
Dim sAssemblyName = oModelLink.FileName
Dim oAsmDoc As AssemblyDocument = oApp.Documents.Open(sAssemblyName)
Dim oOccurrences As Occurrences = oAsmDoc.Occurrences
BR,
Tushar Suradkar
http://surfandcode.blogspot.in
