how to hide bending line /axis
hi Jason
another question...
how can i hide bending line on a draft drawingview ?
id like to set hide bending line /axis property
after AddSheetMetalView seSheetMetalFlatView
is it possible to hide also quote line?
can you help me?
thanks
Posted by: massimo furlan
Post date: 7/25/2013 2:51:01 PM
3 REPLIES 3
The only way I found to turn bend lines on and off via code is by editing the sesmf.ini file. This was in ST4, there may be a better way in ST5/ST6.
Posted by: Terry Tyson
Post date: 7/29/2013 10:11:48 AM
Thank you Terry
can you take a look at the attached images?
i think i can modify property of drawing.... like in this image
[attachment=207]Immagine1.png[/attachment]
[attachment=208]Immagine2.png[/attachment]
Post date: 7/29/2013 11:57:22 AM
It all depends on what is exposed through the API. If the calls are available, use them. There is more and more available each version.
Post date: 7/30/2013 9:32:38 AM
