how to use the method settransform for a highlightset
Hallo,
i´m working with vb.net and SolidEdge V19SP9.
I want to create a highlightsets within parts  from subassamblies.  Before displaying the highlightsets with object.draw()  i have to transform the position with the method object.settransform(Matrix).
but I don´t know how to build the Matrix (array).
The layout of the array is column-major order.
how can I create such a array in vb.net?
Martin
Posted by: Martin Rendler
Post date: 11/12/2007 6:41:50 AM
RE: how to use the method settransform for a highlightset
Martin,
I've dealt with transforms before but it was mostly over my head. You might file an IR for an example and see what you get.
Posted by: Jason Newell
Post date: 11/18/2007 8:47:42 PM
