how to write a code to create an assembly?
hello all, can someone tell me how to write a code to create an assembly using  Solid Edge vb APIs. I have already created some swept part models using vb
Posted by: makarand kulkarni
Post date: 7/28/2009 10:03:28 PM
RE: how to write a code to create an assembly?
chapter 7 of the Solid Edge ST Programmer's Guide gives you a good introduction. You have quick access to the document via the help menu of Solid Edge ST.
Also the previous Solid Edge Programmer's Guide (not updated since Solid Edge V15) gives a good help. This document is available for download from GTAC.
Posted by: Wolfgang Kunert
Post date: 7/30/2009 11:19:26 PM
Post date: 7/31/2009 11:23:16 PM
