icons are black
i have a little problem with VB.NET Addin SolidEdge Template.
Both icons are allway black....
I use XP and SolidEdge V18 Beta
Please can you help me - where is m problem.
Thank you...
Public Sub OnConnectToEnvironment(ByVal EnvCatID As String, ByVal pEnvironmentDispatch As Object, ByVal bFirstTime As Boolean) Implements SolidEdgeFramework.ISolidEdgeAddIn.OnConnectToEnvironment
Dim commandNames(1) As String
Dim commandIDs(1) As Integer
Try
commandNames(0) = "cmdAbout\n\nAbout SEAddin1Toolbar\nAbout SEAddin1Toolbar"
commandNames(1) = "cmdOpenFile\n\nOpen File\nOpen File"
commandIDs(0) = 101
commandIDs(1) = 102
addin.SetAddInInfo(Marshal.GetHINSTANCE(Me.GetType().Module).ToInt32(), EnvCatID, "SEAddin1Toolbar", 1, 2, 1, 2, 2, commandNames, commandIDs)
If (bFirstTime) Then
Dim environment As SolidEdgeFramework.Environment
environment = pEnvironmentDispatch
environment.CommandBars.Add("SEAddin1Toolbar", SolidEdgeFramework.SeBarPosition.seBarTop, False, False)
addin.AddCommandBarButton(EnvCatID, "SEAddin1Toolbar", 101)
addin.AddCommandBarButton(EnvCatID, "SEAddin1Toolbar", 102)
End If
Catch ex As Exception
MessageBox.Show(ex.Message)
End Try
End Sub
Posted by: Reza Habibi
Post date: 10/11/2005 2:35:34 AM
RE: icons are black
Reza,
Good to hear from you.
You must use the ReleaseBuild.bat file that was provided with the template. The reason behind this is that VS.NET does not support compiling Win32 resource files which Addin.res is. The ReleaseBuild.bat uses the commandline compiler with a /Win32 switch or something like that.
So, during development, you will not see your icons unless you explicitly use ReleaseBuild.Bat. I must also mention that you must 1st release build from VS.NET before using ReleaseBuild.bat.
Give it a try and let me know how it goes.
Posted by: Jason Newell
Post date: 10/11/2005 2:42:21 AM
RE: icons are black
Hi Jason,
many thanks for your answer - this is the solution.
All your Software is very greatly.
Thank you
Post date: 10/11/2005 7:14:11 PM
