images from assembly and part files
Dear Users,
can i get a macro (.exe) file to extract images from assembly and part files and will save them in the respective folders where part or assembly exist.
please give me links if anybody have it.
or any guidance will be appreciated
Ravi
Posted by: Ravindra Borhade
Post date: 7/27/2011 6:32:12 PM
RE: images from assembly and part files
Ravi,
the VB6 Code below extract StdPicture from SE-Files.
Private SETE As SeThumbnailExtractor
Private Type PICTDESC
cbSizeofStruct As Long
PicType As Long
hImage As Long
xExt As Long
yExt As Long
End Type
Private Type GUID
Part1 As Long
Part2 As Integer
Part3 As Integer
Part4 As Integer
Part5(1 To 6) As Byte
End Type
Private Declare Function OleCreatePictureIndirect Lib "Olepro32" _
(ByRef pPictDesc As PICTDESC, ByRef RIID As GUID, _
ByVal fOwn As Long, ByRef ppvObj As Any) As Long
Private Declare Function IIDFromString Lib "OLE32" _
(ByVal lpsz As String, ByRef lpiid As GUID) As Long
Public Function GetSEPicHandle(ByVal sFileName As String, _
ByRef iPic As StdPicture) As Boolean
Dim hBitMap As Long
On Error GoTo ErrorHandler
Set SETE = New SeThumbnailExtractor
SETE.GetThumbnail sFileName, hBitMap
Set iPic = PictureFromHandle(hBitMap, vbPicTypeBitmap, True)
Set SETE = Nothing
GetSEPicHandle = True
Exit Function
ErrorHandler:
Set SETE = Nothing
Err.Clear
End Function
Private Function PictureFromHandle(ByVal Handle As Long, _
ByVal PictureType As PictureTypeConstants, _
Optional ByVal PictureOwnsHandle As Boolean = False) _
As StdPicture
Dim nPicture As Picture
Dim nPictDesc As PICTDESC
Dim nIID As GUID
Dim nHResult As Long
Const kPictureIID = "{7BF80981-BF32-101A-8BBB-00AA00300CAB}"
With nPictDesc
.cbSizeofStruct = Len(nPictDesc)
.PicType = PictureType
.hImage = Handle
End With
nHResult = IIDFromString(StrConv(kPictureIID, vbUnicode), nIID)
If nHResult Then
GoTo ErrorHandler
Else
nHResult = OleCreatePictureIndirect(nPictDesc, nIID, _
PictureOwnsHandle, nPicture)
If nHResult Then
GoTo ErrorHandler
Else
Set PictureFromHandle = nPicture
End If
End If
Set nPicture = Nothing
Exit Function
ErrorHandler:
Err.Clear
End Function
Gerald
Posted by: Gerald Haberl
Post date: 7/27/2011 8:16:33 PM
