inactivate drawing views for review
Hello!
I'm trying to open a draft on inactivate drawing views for review in vb net. but I do not know the syntax. Anyone knows.
Dim objApplication As SolidEdgeFramework.Application = Nothing
Dim objDocuments As SolidEdgeFramework.Documents = Nothing
Dim objDraft As SolidEdgeDraft.DraftDocument = Nothing
' Connect to a running instance of Solid Edge
objApplication = Marshal.GetActiveObject("SolidEdge.Application")
' Get a reference to the documents collection
objDocuments = objApplication.Documents
' Add a Draft document
objDraft = objDocuments.Open("C:\Dessin2\1285\12856\128569JA28.dft")
thank you in advance.
Posted by: Plante Sylvain
Post date: 1/10/2013 7:58:02 PM
you must set the global parameter. But this ist only valid for the one session of Solid Edge and not be saved.
objApplication.SetGlobalParameter(SolidEdgeFramework.ApplicationGlobalConstants.seApplicationGlobalSessionDraftOpenInactive, True)
Posted by: JR
Post date: 1/11/2013 12:39:26 AM
It works! Smiley Happy
thank you very much JR.
Post date: 1/11/2013 6:45:36 AM
