interpart Links
Hi All
I'm new in SolidEdge Programming. Trying to establish broken links and delete them without using any interactive tools like revision manager.
I'm thinking of the following actions:
1. opening the file and reading information about interpart documents as shown below:
objWriter.WriteLine("")
objWriter.WriteLine("==========Linked-Doc============")
Dim objApplication AsNew RevisionManager.Application
Dim objRmDocument As RevisionManager.Document
Dim objLinkedDocuments As RevisionManager.LinkedDocuments
Dim objLinkedDocument As RevisionManager.Document
Dim sActiveDoc AsString = objDocument.FullName
objApp.Documents.Close()
objRmDocument = objApplication.Open(sActiveDoc, , False)
objLinkedDocuments = objRmDocument.LinkedDocuments
Try
ForEach objLinkedDocument In objLinkedDocuments
Try
objWriter.WriteLine(" --> " & objLinkedDocument.FullName)
Catch ex As Exception
objWriter.WriteLine(" --> ERROR: Link in " & sActiveDoc)
EndTry
Next
EndTry
The code basically is working but I'm missing some information.
Problem 1: I do get the information for the interpart links where reference exteranl files, but I do not find information about "link is broken" or "link is ok". Is there a method to get this information?
Problem 2: I'm not shure if I get only interpart references listed or if the list contains also all components where are used in the assembly structure. This is why I woud like to get the information/type about link/linktype
Problem 3: If I can not get a list of interpartlinks: Is there a way to scan the fromelements and find the information about links there?
Problem 4: Is there a way to determin a link where
Problem 5: I found th following code in the gtac:
Set objIPLink = objDoc.InterpartLinks
For Each objIPLink In objDoc.InterpartLinks
objIPLink.BreakLink
Next
Unfortunately I do not find the declaration for objIPLink, I do not find the method .InterpartLinks and I do not find the method .BreakLink. What do I have to declare/import to get this functions? (.net not VB6)
I'm looking forward to any help on this topics.
murerro
Posted by: Rolf Murer
Post date: 7/12/2011 5:13:07 AM
RE: interpart Links
Simply check the linked file exists or not.
You get a list of linked files for the top level only. Its on you to recursively traverse the structure by determining all linked files for each linked document which represents an ASM document (check the file extension of the FullName property).
I don't understand your question.
objIPLink.BreakLink
Next
Search the Solid Edge help file index for InterpartLink and InterpartLinks.
Posted by: Wolfgang Kunert
Post date: 7/12/2011 9:36:45 AM
RE: interpart Links
objIPLink.BreakLink
Next
Post date: 7/12/2011 9:36:46 AM
RE: interpart Links
Hi Wolfgang
Thanks for the reply
Problem 1: solved
Problem 2: ok, undestood
Problem 3: I found links where are not referenced to external files. There are also links available where reference to an internal sketch? But this link is broken. Therefore not only a check if the file exists helps on this situation. Here I should be able to check if the link is broken or not. I was expecting to scan the form elements or sketches. But I don't know how to do it. (see also attachment)
Problem 4: I had probably a leek in my brain :-) The sentence makes no sence....
Problem 5: ok, I will scan the docu.
Regards and many thanks
Rolf
Post date: 7/17/2011 11:31:03 PM
