is it possible to simulate a mouse click to get objects at a programmed point?
Hi
I want to know how to do the equivalent of a mouse click to retieve objects at an x, y, z point that I specifiy in the code. The mouseevents custom macro supplied with Solid Edge achieves this with a mouse click, but how do I do this if I want to specify the point rather than getting it from a mouse click?
Re: is it possible to simulate a mouse click to get objects at a programmed point?
If you're using VB, this will let you click anywhere on the screen (not necessarily in the SE window).
It could be a solution if you don't find what you're looking for.
<DllImport("user32.dll")>
Private Shared Sub mouse_event(dwFlags As UInteger, dx As UInteger, dy As UInteger, dwData As UInteger, dwExtraInfo As Integer)
End Sub
<Flags()>
Public Enum MouseEventFlags As UInteger
MOUSEEVENTF_ABSOLUTE = &H8000
MOUSEEVENTF_LEFTDOWN = &H2
MOUSEEVENTF_LEFTUP = &H4
MOUSEEVENTF_MIDDLEDOWN = &H20
MOUSEEVENTF_MIDDLEUP = &H40
MOUSEEVENTF_MOVE = &H1
MOUSEEVENTF_RIGHTDOWN = &H8
MOUSEEVENTF_RIGHTUP = &H10
MOUSEEVENTF_XDOWN = &H80
MOUSEEVENTF_XUP = &H100
MOUSEEVENTF_WHEEL = &H800
MOUSEEVENTF_HWHEEL = &H1000
End Enum
mouse_event(MouseEventFlags.MOUSEEVENTF_LEFTDOWN, x_coordinate, y_coordinate, 0, 0)
mouse_event(MouseEventFlags.MOUSEEVENTF_LEFTUP, x_coordinate, y_coordinate, 0, 0)
Siemens PLM Software, Inc.
Project Test Engineer (Automation)
