isDocumentFOP
Has anybody tried to solve the mystery of how to use 'isDocumentFOP'?
I don't understand return value. It is an integer. How do we interpret it? How do I use it and for what purpose.
Syntax and Example in the help file do not explain anything.
The description column in Document class members is blank.
I am lost.
Can anybody show me the way out.
Or is there any other way to find if a document is FOP member and find the 'master' and other members of the Family? I am using VB.
Thanks for any help.
Posted by: Sanjay Kulkarni
Post date: 3/21/2012 3:56:01 AM
Re: isDocumentFOP
Hi Sanjay,
the value returned to the parameter given by reference seems to be one of the DocFOPStatus Enumeration.
You are right - the Solid Edge API reference documentation and most of its examples are not as good as they could/should be Smiley Sad
Posted by: Wolfgang Kunert
Post date: 3/21/2012 2:29:51 PM
