layers and dimensions
Hi!
I see that in layers tree there is a button "Move Element" which allows me to move dimension to the chosen layer.
Is there any api function in SE which will allow me to move dimension from default layer in Draft document to another layer?
Or is there any other way to hide dimension from drawing view?
Posted by: P Sh
Post date: 5/31/2010 4:58:49 AM
RE: layers and dimensions
Polina,
This code will do the job;
Public Sub MoveToLayer()
On Error Resume Next
Dim objApp As SolidEdgeFramework.Application
Dim objDoc As SolidEdgeDraft.DraftDocument
Dim objSheet As SolidEdgeDraft.Sheet
Dim objDimensions As SolidEdgeFrameworkSupport.Dimensions
Dim objDimension As SolidEdgeFrameworkSupport.Dimension
Dim strNewLayerName As String
'Get SE
    Set objApp = GetObject(, "SolidEdge.Application")
    If Err  Then
        Err.Clear
        Set objApp = CreateObject("SolidEdge.Application")
    End If
    objApp.Visible = True
'Set
    Set objDoc = objApp.ActiveDocument
    Set objVariables = objDoc.Variables
    Set objSheet = objDoc.ActiveSheet
    Set objDrawingViews = objSheet.DrawingViews
    Set objDimensions = objSheet.Dimensions
    strNewLayerName = "Other Layer"
    For Each objDimension In objDimensions
        objDimension.Layer = strNewLayerName
    Next
'Release objects
    Set objApp = Nothing
    Set objDoc = Nothing
    Set objSheet = Nothing
    Set objDimensions = Nothing
    Set objDimension = Nothing
End Sub
Posted by: Wouter Sloof
Post date: 5/31/2010 8:53:19 PM
Thank you a lot, ErWo!!!!
Posted by: P Sh
Post date: 6/1/2010 2:58:42 AM
