macro load upon startup ST2
Does any one knows how to load a macro upon startup in Solid Edge ST2 or ST3.
We have a limited number of SE licenses. So I wrote a macro that monitors the idle time in SE. If the user do noting in SE for an hour, SE shutdowns. But I don't want the users to load the macro manually. (They may "forget"). So I'm looking for some way to start the macro automatically at SE startup.
I appreciate any help.
RE
Posted by: Ricardo Espinosa
Post date: 3/1/2011 8:08:30 AM
3 REPLIES 3
RE: macro load upon startup ST2
Ricardo,
You'll need an Addin for what you're wanting.  Here is an article I wrote on creating addins for Solid Edge: Solid Edge ST Addins - Part I.
Posted by: Jason Newell
Post date: 3/1/2011 3:50:47 PM
Thanks Jason,
Have you any example project of Solid Edge Add-in written in vb.net?
Thank you.
Ricardo
Post date: 3/2/2011 2:39:28 AM
Hi Ricardo,
how about the sample under ST3-Installation-Directory\SDK\Samples\Addins\VB .NET ?
Posted by: Wolfgang Kunert
Post date: 3/2/2011 3:54:24 AM
