making assembly
I have three part files and want to make an assembly of them.
Need to apply planar relationship to them.
How to call the part files in assembly and apply the required relationship
waiting for help
ali :silly:
Posted by: ali kamran
Post date: 3/28/2013 9:28:34 AM
making assembly
ali,
Look at the "Adding New Assembly Relationships" section of the Solid Edge .NET Programmer's Guide.
Make sure this is really how you want to build your assemblies. When you insert a part into the assembly via the API, the part is grounded. You can then easily use .PutTransform() to move the part to any location and orientation you want. If you build your parts with the origin in the right location, building assemblies becomes easy. Using grounded parts, your assembly will not "blow up" due to a small problem with a feature or change in dimension.
Keep in mind, if you do decide to use planes, you need to delete the ground relationship first.
Posted by: Terry Tyson
Post date: 3/28/2013 3:06:50 PM
making assembly
thanks.
can you tell me the command,how to add part files/
ali
Post date: 3/30/2013 12:17:20 AM
making assembly
Look at page 77 in the Programmer's Guide.
Post date: 4/2/2013 7:57:17 AM
