Reply
Solved! Go to solution
model->GetPhysicalProperties() - Does this always return values in Meter and kg ?
Can anyone confirm whether the function model->GetPhysicalProperties() always returns the Mass, Density, Volume and Area as Meter and kg values?
Even though requesting the unit of length and weight for a model can return MM or lb, it seems the function always retursn the values in Meter and kg?
Just want to know if anyone else can confirm it or has had it confirmed by Siemens in the past?
Chris.
Chris Mann | Development Director
Concurrent Systems, Inc. Ltd.
http://www.csi-europe.com
Solution
Solution
Accepted by topic author csi
‎10-01-2015 11:24 AM
Re: model->GetPhysicalProperties() - Does this always return values in Meter and kg ?
Chris,
yes, internally and via API you always have to use or get lengths/weights in meter/Kg
Kind regards,
Wolfgang Kunert - www.wksyspro.de
Perfect - Thanks for confirming!
