open a file in revision manager
Helo all
i try to open a file in revisionmanager app
here is the code
System.Diagnostics.Process proc = new System.Diagnostics.Process();
proc.EnableRaisingEvents = false;
proc.StartInfo.FileName = "iCnct";
proc.StartInfo.Arguments = @"C:\\part1.par";
proc.Start();
but it doesnt work, send me next messagebox inside RevisionManager:
No active pcf document available. Open support CAD document, before adding any un-supported Non-CAD document links into the pcf
can anyone help me please..
Posted by: Diego Armando
Post date: 11/30/2012 6:04:05 PM
try with "/r " for arguments like:
proc.StartInfo.Arguments = @"/r C:\\part1.par";
Posted by: JR
Post date: 12/3/2012 12:21:35 AM
it works and this is the code if someone needs to open a file
[i]//Use double quotes inside the quotes to force it to be evaluated...[/i]
proc.StartInfo.Arguments = @"""C:\Documents and Settings\user\Desk\part1.par"" [b]/r[/b]";
proc.Start();
thanks alot!
Post date: 12/4/2012 10:15:24 AM
