part list in excel
is it possible write in column "A" (in an excel file), all part list of an assembly indicated in cell "B2"?
Re: part list in excel
It is certainly possible as the Solid Edge API is COM based. That means that you can use Excel VBA to automate Solid Edge and extract the information that you require. The Samples for Solid Edge on CodePlex has a SolidEdge.Assembly.BOM project that demonstrates how to traverse an assembly. It's written in .NET but should give you enough of clues how to use the API.
Jason Newell
Applications Architect
www.jasonnewell.net
