place mass field to file properties - custom tab
For solidedge v.20 (for st3 i guess is the same) how can you make a customization so that a copy of the mass field in a solidedge part file (.psm, .prt) found at inspect- physical properties – mass to be available automatically updated in file- file properties – custom in a custom field called mass? Thank you.
Posted by: Farkas Alpar
Post date: 3/15/2011 11:43:50 PM
