please answer me-EditRelativeToCoordinateSystem
vb6
Call objcoordi1.EditRelativeToCoordinateSystem(False, objcoordi2, (1)?,(2) ?, 0, 0,0 , Text12d * PI / 180, Text22d * PI / 180, Text32d * PI / 180)
(1) [AnyEdgeToDefineOrigin As Object]  => ?
(2)[KeyPointFlags As KeyPointType] => ?
Posted by: lim j h
Post date: 2/21/2009 10:54:52 PM
1 REPLY 1
RE: please answer me-EditRelativeToCoordinateSystem
The SDK Documentation says:
AnyEdgeToDefineOrigin = "Specifies the edge on which the point lies."  I assume this is referring to any SolidEdgeGeometry.Edge.  I could be wrong on that though.  Using Solid Edge Spy, I connected to Solid Edge with a part file and found an Edge object at Application -> ActiveDocument -> Models(1) -> ExtendedProtrusions(1) -> SideFaces(1) -> Edges(1).
KeyPointType = SolidEdgeFramework.KeyPointType - "Member of the KeyPointType constant set that specifies where the key point lies on the edge."
Posted by: Jason Newell
Post date: 2/22/2009 5:09:45 PM
