print 11 x 17 problems
i have a problem when i try to print in 11x17 sheet....the efective plotting area is 10.6 x 8.2 and most by 11 x 17 i can't change the paper lenght and the print is small....
Re: print 11 x 17 problems
I have this problem ocasionally with a specific printer and with a particular Draft file. For some reason the Effective Plotting Area will not change from letter size to tabloid (with printing preferences set to tabloid on the printer). Thought it was the print driver but the problem doesn't always occur.
