printdft in ST9
We have been using a modified version of the PrintDft VB for quick viewing of our files, but when we load ST9 all of the icons for file open, print, zoom area, dynamic zoom, fit, and pan show up blank.  Does anyone know of a fix for that?
Re: printdft in ST9
Are you using the AxSEDraftX control?  I have seen that and it seems to be independent of video cards, drivers and Win 7 & 10.
Brian
Re: printdft in ST9
I'm quite the novice (or less) regarding this stuff.  We had someone re-do the stock PrintDft program to this and it appears we use the SEDraftX.ocx and not the AxSEDraftX you mentioned.  I included a zip file of the code (if that helps any).https://dl.dropboxusercontent.com/u/99266594/code.zip
Re: printdft in ST9
That is the same control, it is just named a little differently in VBA or VB6 that you are using.  In VB.NET and C#, the icons are missing too.
Re: printdft in ST9
Issue should be fixed in ST9 MP5.
