Reply
printing with SE viewer
[ Edited ]
Hi all,
I'm try to vrite a VB macro to open e DFT with the free viewer of Solid Edg,
but I can't.
With SE I start :
Dim objSEApp As SolidEdgeFramework.Application
Set objSEApp = CreateObject("solidedge.application"
but with SEViewer how I must start?
Thank you
Delki Trolese
Italy
Posted by: Delki Trolese
Post date: 6/18/2007 2:04:21 AM
RE: printing with SE viewer
[ Edited ]
Delki,
You'll need to add a reference to "C:\Program Files\Solid Edge VXX\Program\SEDraftX.ocx" which is an ActiveX control.  Then you drop the control onto a form and you can use it.  I don't have an example readily available but I can help you if you still need help.
Posted by: Jason Newell
Post date: 6/18/2007 4:33:38 AM
[ Edited ]
Thank's!
Can you tell me how to inser a ActiveX control for VB6 in VB2005.net?
Thank you.
Delki Trolese
Italy
Post date: 6/18/2007 5:16:05 AM
[ Edited ]
Delki,
I attached a .zip that contains some screen shots Visual Basic .NET 2005.  Once you have the ActiveX control in your Toolbar, you can drag and drop it on any form.
Post date: 6/18/2007 8:04:11 PM
[ Edited ]
Thank you very much!
You help me!
Delki Trolese
Italy
Post date: 6/18/2007 8:35:40 PM
