problem about EdgePtr
Hello all,
I'working with VC2003 and SEV17, now i have a problem about EdgePtr.
At first I can get the EdgePtr pEdge, and i can know, that this edge a circle is, then
LPDISPATCH edgeGeo = pEdge->GetGeometry();
CirclePtr pCircle = pEdge;//hier is the pCircle not NULL!
but
double radius = pCircle->GetRadius();//hier get the exception:Access violation reading location 0x00000000
any ideas?
thanks
Julia
Posted by: Julia Schneider
Post date: 11/14/2007 2:54:20 AM
RE: problem about EdgePtr
Hello everyone,
please help me!!
I want to get the circleData from a EdgePtr, how can I do that?
thanks in advance
Julia
Post date: 11/14/2007 9:47:28 PM
Julia,
Upload some simple example source code and an example Solid Edge file and I will take a look at it.
Posted by: Jason Newell
Post date: 11/18/2007 8:03:06 PM
Hello Jason,
here is a simple example source code.
I working with vc2003 and SE17 and SE20
thanks in advance
Julia
Post date: 11/18/2007 9:30:13 PM
Post date: 11/18/2007 9:32:14 PM
Julia,
No error checking in my example as it's for demonstration only.// JuliaDemo.cpp : Defines the entry point for the console application.//#include "stdafx.h"int _tmain(int argc, _TCHAR* argv[]){ HRESULT hr = S_OK; CoInitialize(NULL); SolidEdgeFramework::ApplicationPtr pApplication = NULL; SolidEdgePart:Smiley TongueartDocumentPtr pPartDoc = NULL; SolidEdgePart::ModelPtr pModel = NULL; SolidEdgeGeometry::BodyPtr pBody = NULL; SolidEdgeGeometry::EdgesPtr pEdges = NULL; SolidEdgeGeometry::EdgePtr pEdge = NULL; SolidEdgeGeometry::CirclePtr pCircle = NULL; pApplication.GetActiveObject(_T("SolidEdge.Application")); pPartDoc = pApplication->ActiveDocument; pModel = pPartDoc->Models->Item((LONG)1); pBody = pModel->Body; pEdges = pBody->GetEdges(SolidEdgeGeometry::igQueryAll); for (LONG i = 1; i Count; i++) { pEdge = pEdges->Item(i); SolidEdgeGeometry::GNTTypePropertyConstants gntType = pEdge->Type; SAFEARRAY *pCenterPoint = SafeArrayCreateVector(VT_R8, 0, 0); SAFEARRAY *pAxisVector = SafeArrayCreateVector(VT_R8, 0, 0); double Radius = 0; switch (pEdge->Type) { case SolidEdgeGeometry::igBody: break; case SolidEdgeGeometry::igBSplineCurve: break; case SolidEdgeGeometry::igBSplineSurface: break; case SolidEdgeGeometry::igCircle: break; case SolidEdgeGeometry::igCone: break; case SolidEdgeGeometry::igCurve: break; case SolidEdgeGeometry::igCurveBody: break; case SolidEdgeGeometry::igCurvePath: break; case SolidEdgeGeometry::igCylinder: break; case SolidEdgeGeometry::igEdge: pCircle = pEdge->GetGeometry(); /* Put breakpoint here and look at the results of GetCircleData() */ /* Add pCenterPoint, pAxisVector & Radius to your watch window */ pCircle->GetCircleData(&pCenterPoint, &pAxisVector, &Radius); /* Clear Radius to make sure GetRadius() changes the value */ Radius = 0; /* This also works */ Radius = pCircle->GetRadius(); /* This is here so that you can see the results of GetRadius() */ Radius = 0; break; case SolidEdgeGeometry::igEdgeUse: break; case SolidEdgeGeometry::igEllipse: break; case SolidEdgeGeometry::igFace: break; case SolidEdgeGeometry::igLine: break; case SolidEdgeGeometry::igLoop: break; case SolidEdgeGeometry::igParamBSplineCurve: break; case SolidEdgeGeometry::igPlane: break; case SolidEdgeGeometry::igShell: break; case SolidEdgeGeometry::igSphere: break; case SolidEdgeGeometry::igTorus: break; case SolidEdgeGeometry::igVertex: break; } } pCircle = NULL; pEdge = NULL; pEdges = NULL; pBody = NULL; pModel = NULL; pPartDoc = NULL; pApplication = NULL; CoUninitialize(); return 0;}
Post date: 11/19/2007 1:03:05 PM
Hello Jason,
thank you very much!!
but if I don't know wether an Edge is a circle or cone, how can I get the Type of the Edge?
(from pEdge->Type get only "igEdge" not "igCircle" or "igCone")
thanks a lot
Julia
Post date: 11/20/2007 12:18:27 AM
Julia,
I also found it odd that pEdge->Type always return type igEdge. Not quite sure why and I didn't have time to look into it. I was focusing on getting you a working example of GetRadius().
Post date: 11/25/2007 5:06:25 PM
