problem while deploying project
   I'm facing a weird problem while deplying my application on client side.
I'm using vb.net 2008 and SE v 20.
Now problem is SE version at my client side is without any patch installed. (20.0.0.96)
My version of SE is with patch (20.0.09.03)
When i deploy application, It doesnt work at client side. It just gets stoped abruptly without any error.
I found out that if i build setup using SE without patch, It works fine on client side.
How to get rid of this version incompatibiliy issue?
Thanks ,
Myth.
Posted by: Mithun **bleep**ole
Post date: 4/22/2009 9:23:11 PM
RE: problem while deploying project
Unless you're using something in the API that was introduced in a later server pack, it should work fine. Regarding the abrupt stop, are you using try\catch blocks in your code where you can catch any exception and show a message box?
Posted by: Jason Newell
Post date: 4/24/2009 7:28:00 AM
I resolved the issue.
I was shipping tlb files also in addition to Interop files.
I removed those tlb files from installer, now it runs just fine.
Thanks for help,
Myth.
Post date: 4/27/2009 10:43:45 PM
