problem with keypoint curves
Hi everyone,
I have trouble's with creating keypoint curves.
I use VB.net 2010 and I get some weird(for me) error message after several procedure.
I try many different ways, here is my last trying:
(this code assumes that SE is running with an open part doc and have a simple
extruded protrusion on a rectangular profile base)
Here is the VB.net code:
Imports System.Runtime.InteropServices
Module Module1
    Sub Main()
        Dim SEApplication As SolidEdgeFramework.Application = Nothing
        Dim partDoc As SolidEdgePart.PartDocument = Nothing
        Dim curveCollect As SolidEdgePart.KeyPointCurves = Nothing
        Dim edgeCollect As SolidEdgeGeometry.Edges = Nothing
        Dim topFace As SolidEdgeGeometry.Face = Nothing
        Dim numEdges As Integer = 2
        Dim edgeSet() As SolidEdgeGeometry.Edge = New SolidEdgeGeometry.Edge(1) {}
        Dim keyPointType() As SolidEdgeConstants.KeyPointType = New SolidEdgeConstants.KeyPointType(1) {}
        Dim keyEndCond As SolidEdgePart.KeypointEndConditionConstants = SolidEdgePart.KeypointEndConditionConstants.seKeypointEndConditionNatural
        Try
            SEApplication = Marshal.GetActiveObject("SolidEdge.Application")
            partDoc = SEApplication.ActiveDocument
            topFace = partDoc.Models.Item(1).ExtrudedProtrusions.Item(1).TopCap
            edgeCollect = topFace.Edges
            curveCollect = partDoc.Constructions.KeyPointCurves
            edgeSet(0) = edgeCollect.Item(1)
            edgeSet(1) = edgeCollect.Item(2)
            keyPointType(0) = SolidEdgeConstants.KeyPointType.igKeyPointMiddle
            keyPointType(1) = SolidEdgeConstants.KeyPointType.igKeyPointMiddle
            curveCollect.Add(numEdges, edgeSet, keyPointType, keyEndCond)
The exception code after the last line:
" Could not load file or assembly 'Interop.SolidEdgeFramework, Version=1.0.0.0, Culture=neutral, PublicKeyToken=null' or one of its dependencies... "
I got the same error even if I put "Nothing" as arguments and after KeypointCurve.GetAllPoints procedure.
I use SolidEdge ST2. Sorry for my english and thanks for your help!
Posted by: Kikke Nemet
Post date: 9/26/2011 12:34:32 PM
Re: problem with keypoint curves
Copy Interop.*.dll to binary(.exe) folder solves the file not found problem.
But I am getting invalid argument exception afterwards.
