property.get_Value() doesn't work in C#
Using ST7 and Visual Studio 2017:
In VB,
seProp.Value
works.
In C#,
seProp.get_Value()
does not work.
Please help.
Terry Tyson
Software Automation Designer
Re: property.get_Value() doesn't work in C#
Hello Terry,
to get file property, you can do this: (C#)
class Program
        [STAThread]                         // Work with file properties
        static void Main(string[] args)
            // Declare your main variables
            SolidEdgeFramework.Application seApplication = null;
            SolidEdgeFramework.Documents seDocuments = null;
            // Declare your document variables
            SolidEdgePart.PartDocument sePartDoc = null;
            // Declare variables about file properties collection
            SolidEdgeFramework.PropertySets propertySets = null;
            // Declare variable about Summary Information properties
            SolidEdgeFramework.Properties propertiesSummary = null;
            SolidEdgeFramework.Property title = null;
            SolidEdgeFramework.Property subject = null;
            SolidEdgeFramework.Property author = null;
            SolidEdgeFramework.Property comments = null;
            // Declare variable about Project Information properties
            SolidEdgeFramework.Properties propertiesProject = null;
            SolidEdgeFramework.Property documentNumber = null;
            SolidEdgeFramework.Property revision = null;
            SolidEdgeFramework.Property projectName = null;
            try
                // Register
                OleMessageFilter.Register();
                // Connect your Solid Edge
                seApplication = SolidEdgeUtils.Connect(true);
                // Get your Document Collection
                seDocuments = seApplication.Documents;
                // Get Active Document
                sePartDoc = (PartDocument)seApplication.ActiveDocument;
                // Get collection of Property Sets
                propertySets = (PropertySets)sePartDoc.Properties;
                // Get collection of Sumary Information properties
                propertiesSummary = propertySets.Item("SummaryInformation");
                // Get properties
                title = propertiesSummary.Item("Title");
                subject = propertiesSummary.Item("Subject");
                author = propertiesSummary.Item("Author");
                comments = propertiesSummary.Item("Comments");
                // Write the value of each property
                title.set_Value("Write here the new title");
                subject.set_Value("Write here the text to subject");
                author.set_Value("Write here the author");
                comments.set_Value("Write the comment of your part document");
                // Now, the same thing to project properties
                propertiesProject = propertySets.Item("ProjectInformation");
                // Get properties
                documentNumber = propertiesProject.Item("Document Number");
                revision = propertiesProject.Item("Revision");
                projectName = propertiesProject.Item("Project Name");
                // Define the text of each property
                documentNumber.set_Value("012345");
                revision.set_Value("A");
                projectName.set_Value("Your project name");
            catch (Exception e)
                Console.WriteLine(e.Message);
            finally
                // Ungister
                OleMessageFilter.Unregister();
For step-by-step, see this video:
Kabir Costa
Industrial Designer
kabircosta@gmail.com
To get value as a string, do it:
                string titleString = (string)title.get_Value();
                string documentNumberString = (string)documentNumber.get_Value();
                Console.WriteLine(titleString);
                Console.WriteLine(documentNumberString);
Kabir Costa
Industrial Designer
Kabir, thanks for the reply. I'm still getting a "Member not found" error. No matter how I try to use it, the .get_Value() method throws this error. What version of SE are you using?
Terry Tyson
Also, I'm trying to get the data from the Custom properties if that makes a difference. I've had no problem with this in VB, only in C#.
Terry Tyson
Are you can send images of the problem?
Kabir Costa
Industrial Designer
I've switched to using the SolidEdgeFileProperties class instead to bypass opening Solid Edge but I'm still having issues with C#. The VB code works just fine:
Sub Main()
        Dim sePropSets As SolidEdgeFileProperties.PropertySets = Nothing
        Try
            sePropSets = New SolidEdgeFileProperties.PropertySets
            sePropSets.Open("C:\Users\ttyson\Documents\ERP\Thermal\LowerFrameTestModels\Asm1.asm", True)
            Dim seCustomProps As SolidEdgeFileProperties.Properties = sePropSets.Item("Custom")
            For Each seProp As SolidEdgeFileProperties.Property In seCustomProps
                Console.WriteLine(seProp.Name + ": " + seProp.Value)
            Next
        Catch ex As Exception
        End Try
        Console.ReadLine()
    End Sub
But I can't get anywhere with the C# code. As you can see, the PropertySets object doesn't even have an Item property exposed.
Not only that but I get this error even trying to run the previous line.
There is nothing wrong with the file, I can open it and use it in Solid Edge and the VB code runs on it every time giving me what I'm looking for. I may just have to do this project in VB.
VBoutput.JPGVB output
Terry Tyson
Try this:
using SolidEdgeFileProperties;
PropertySets filePropertySets;
Properties fileProperties;
filePropertySets = new  PropertySets();
try
  filePropertySets.Open(fileFullPath, System.IO.FileShare.ReadWrite);
catch (System.Runtime.InteropServices.COMException e)
 return e.Message + e.ToString();
fileProperties = (Properties)filePropertySets["Custom"]; // Use ["Custom"]
If it still does not work, see this post:
https://community.plm.automation.siemens.com/t5/Solid-Edge-Developer-Forum/Document-properties-unava...
Kabir Costa
Industrial Designer
The file must not be open in Solid Edge.
Kabir Costa
Industrial Designer
For get_Value(), try this instead:
string value = ((dynamic)seProp).Value;
Where seProp is of type SolidEdgeFramework.Property
You can set a value with ((dynamic)seProp).Value = "New Value";
Siemens PLM Software, Inc.
Project Test Engineer (Automation)
