"GetReferenceToGraphicMember" api return Nothing
Hello All,
I have following code in VB6.0
Draft file contains 3 views of same modelink.
'Declarations
Dim oDVCircle As SolidEdgeDraft.DVCircle2d
Dim oReference As Object
Dim oFrontView As SolidEdgeDraft.DrawingView
'Syntax
Call oFrontView.GetReferenceToGraphicMember(oDVCircle, oReference)
I found that above API retuns Nothing while this API is working fine with SE v20.
I would appreciate if any work around suggested.
Thanks in advance,
Ritesh
Posted by: ryp
Post date: 5/8/2012 5:43:58 AM
Re: "GetReferenceToGraphicMember" api return Nothing
Sorry! I missed to mention this error is observed in SE ST4 and working fine with SE v20
Ritesh
Posted by: ryp
Post date: 5/8/2012 5:46:26 AM
Hello JR,
Thanks for your reply.
I had tried with the "GetReferenceToGraphicMember2",as you had mentioned below,but it also shows error.
oReference = oFrontView.GetReferenceToGraphicMember2(oDVCircle)
I am getting this error with Drawing view objects such as DVCircle2d,DVArc2d,DVLine2d etc and it is working fine with graphic object on sheet such as Circle2d,Arc2d,Line2d.
Ritesh...
Posted by: ryp
Post date: 5/13/2012 10:15:13 PM
