"disperse assembly" command in API?
Hello everybody,
i'm searching for the disperse command as it is useable in assembly environment. how can i use this as an API command on a selected asm?
Hopefully someone here can help me.
Re: "disperse assembly" command in API?
use the DisperseSubassembly() method of the AssemblyDocument.
JB
SE ST10
