revision manager to get parent of part or assembly
I've been trying to use revision manager to search for the parent of a part or assembly file. I could search for child using the linkeddocument but I cannot figure out a way to find what assembly a certain part belongs to. Thanks.
Posted by: Linh Tran
Post date: 3/20/2012 11:11:03 AM
Re: revision manager to get parent of part or assembly
Hi Linh,
you have to use WhereUsed to find any parents of an asm/par/psm.
Posted by: Wolfgang Kunert
Post date: 3/20/2012 2:29:21 PM
Hi linh
Wolfgang is right. the link to parts is always at the parent asm or dft, and since a single part can be placed in many asm and dft the whereused can be terribly slow crawling through. I've also battled with it and eventually created a program that creates an all links database (for the whole cad lib). when i need to find a parent i search the database (takes about 2 sec) instead of crawling with whereused.
Alon
Posted by: alon raviv
Post date: 3/21/2012 4:58:39 AM
