revision manager
Hello All!
Do you have any idea how to translate source code
'Attach to application and open file
Set objRevisionManager = CreateObject("RevisionManager.Application")
'Open an assembly
Set objDoc = objRevisionManager.Open(strSE_TrainingDir & "aaa.asm")
from VB to C#?
I had tried
RevisionManager.Application objRevisionManager =
(RevisionManager.Application) CreateObject("RevisionManager.Application");
SolidEdgeAssembly.AssemblyDocument assemDocRev =
(SolidEdgeAssembly.AssemblyDocument) objRevisionManager.Open(assemDoc.FullName, 0, true);
but the CreateObject function does not exist.
Jara
Posted by: Jara Ctverak
Post date: 2/5/2007 11:16:00 PM
RE: revision manager
Hi Jara,
Use the Activator.CreateInstance method (The CreateObject method exists in the Microsoft.VisualBasic namespace when you reference the Microsoft.VisualBasic.dll, but this is only for VB6 backwards compatibility). See here for more details.
Cheers
Calum
Posted by: Calum McLellan
Post date: 2/6/2007 9:46:14 AM
