saving options
Greetings,
I am new to the forum and to programming solid edge macros and add ins. I have been looking around for some code examples to get myself started but it is a little overwhelming.
What i am looking to do is rather simplistic but i don't know how hard it would be to code and I am not sure where would be a good place to start.  Regardless what I would like is a macro that does something like this.
when the save button is pressed enter a sub that looks something like this
If CurrentFile == sheet metal then
     Save CurrentFile.psm
     Save CurrentFile.dxf
else if CurrentFile == Draft then
     Save CurrentFile.dft
     Save CurrentFile.pdf
EndIf
Eventually i would like this to lead into something that would scan a BOM and check all parts if they have a dft, dxf and pdf as needed.  We need the Dxf's and pdf's for part we send out to get laser cut and having out of date files has been a problem so i would like to find a way that elimiates that problem.
Thank you Very much for any help that can be given. I am most appreciative.
Gold bug
Posted by: Gold Bug
Post date: 7/13/2010 5:29:28 AM
