seriously now. I need help CaptureRelationships
Can anyone, anyone at all help me apply a capture fit.    I took this example for adding a mate from the new programmers guide and I just want to add the capture fit for the single axial align relationship.
Imports SolidEdgeGeometry
Imports System.Runtime.InteropServices
Module Module1
    Sub Main()
        Dim objApplication As SolidEdgeFramework.Application = Nothing
        Dim objDocuments As SolidEdgeFramework.Documents = Nothing
        Dim objAssembly As SolidEdgeAssembly.AssemblyDocument = Nothing
        Dim objOccurrences As SolidEdgeAssembly.Occurrences = Nothing
        Dim objOccurrence1 As SolidEdgeAssembly.Occurrence = Nothing
        Dim objOccurrence2 As SolidEdgeAssembly.Occurrence = Nothing
        Dim objPart As SolidEdgePart.PartDocument = Nothing
        Dim objModels As SolidEdgePart.Models = Nothing
        Dim objModel As SolidEdgePart.Model = Nothing
        Dim objRevolvedProtrusions As SolidEdgePart.RevolvedProtrusions = Nothing
        Dim objRevolvedProtrusion As SolidEdgePart.RevolvedProtrusion = Nothing
        Dim objRevolvedCutouts As SolidEdgePart.RevolvedCutouts = Nothing
        Dim objRevolvedCutout As SolidEdgePart.RevolvedCutout = Nothing
        Dim objFaces As SolidEdgeGeometry.Faces = Nothing
        Dim objFace As SolidEdgeGeometry.Face = Nothing
        Dim objGeometry As Object = Nothing
        Dim objScrewConicalFace As SolidEdgeGeometry.Face = Nothing
        Dim objNutConicalFace As SolidEdgeGeometry.Face = Nothing
        Dim objRefToCylinderInScrew As SolidEdgeFramework.Reference = Nothing
        Dim objRefToConeInNut As SolidEdgeFramework.Reference = Nothing
        Dim objRelations3d As SolidEdgeAssembly.Relations3d = Nothing
        Dim objGroundRel As SolidEdgeAssembly.GroundRelation3d = Nothing
        Dim objRelNuttoScrew As SolidEdgeAssembly.AxialRelation3d = Nothing
        Try
            ' Connect to a running instance of Solid Edge
            objApplication = Marshal.GetActiveObject("SolidEdge.Application")
            ' Get a reference to the documents collection
            objDocuments = objApplication.Documents
            ' Create a new assembly document
            objAssembly = objDocuments.Add("SolidEdge.AssemblyDocument")
            ' Get a reference to the occurrences collection
            objOccurrences = objAssembly.Occurrences
            ' Add the first occurrence
            objOccurrence1 = objOccurrences.AddByFilename("C:\Screw.par")
            ' Get a reference to the occurrence document
            objPart = objOccurrence1.OccurrenceDocument
            ' Get a reference to the models collection
            objModels = objPart.Models
            ' Get a reference to the one and only model
            objModel = objModels.Item(1)
            ' Get a reference to the revolved protrusions collection
            objRevolvedProtrusions = objModel.RevolvedProtrusions
            ' Get a reference to the first revolved protrusion
            objRevolvedProtrusion = objRevolvedProtrusions.Item(1)
            ' Get a reference to the side faces collection
            objFaces = objRevolvedProtrusion.SideFaces
            ' Loop through the faces
            For Each objFace In objFaces
                ' Get a reference to the geometry object
                objGeometry = objFace.Geometry
                If objGeometry.Type = GNTTypePropertyConstants.igCylinder Then
                    objScrewConicalFace = objFace
                    Exit For
                End If
            Next
            ' Create the first reference
            objRefToCylinderInScrew = objAssembly.CreateReference(objOccurrence1, objScrewConicalFace)
            ' Add the second occurrence
            objOccurrence2 = objOccurrences.AddByFilename("C:\Nut2.par")
            objPart = objOccurrence2.OccurrenceDocument
            ' Get a reference to the revolved cutouts collection
            objRevolvedCutouts = objModel.RevolvedCutouts
            ' Get a reference to the first revolved cutout
            objRevolvedCutout = objRevolvedCutouts.Item(1)
            objFaces = objRevolvedCutout.SideFaces
                    objNutConicalFace = objFace
                    Exit For
                End If
            Next
            ' Create the second reference
            objRefToConeInNut = objAssembly.CreateReference(objOccurrence2, objNutConicalFace)
            ' All Occurrences placed through automation are placed "Grounded."
            ' You must delete the ground constraint on the second Occurrence
            ' before you can place other relationships.
            objRelations3d = objAssembly.Relations3d
            objGroundRel = objRelations3d.Item(2)
            objGroundRel.Delete()
            ' Rather than passing literal axes to the AddAxial method, pass
            ' references to conical faces, Just as you select conical faces
            ' when you use the interactive Align command.
            objRelNuttoScrew = objRelations3d.AddAxial(objRefToConeInNut, objRefToCylinderInScrew, False)
        Catch ex As Exception
            Console.WriteLine(ex.Message)
            Console.ReadKey(0)
        Finally
            If Not (objRelNuttoScrew Is Nothing) Then
                Marshal.ReleaseComObject(objRelNuttoScrew)
                objRelNuttoScrew = Nothing
            End If
            If Not (objGroundRel Is Nothing) Then
                Marshal.ReleaseComObject(objGroundRel)
                objGroundRel = Nothing
            End If
            If Not (objRelations3d Is Nothing) Then
                Marshal.ReleaseComObject(objRelations3d)
                objRelations3d = Nothing
            End If
            If Not (objRefToConeInNut Is Nothing) Then
                Marshal.ReleaseComObject(objRefToConeInNut)
                objRefToConeInNut = Nothing
            End If
            If Not (objRefToCylinderInScrew Is Nothing) Then
                Marshal.ReleaseComObject(objRefToCylinderInScrew)
                objRefToCylinderInScrew = Nothing
            End If
            If Not (objNutConicalFace Is Nothing) Then
                Marshal.ReleaseComObject(objNutConicalFace)
                objNutConicalFace = Nothing
            End If
            If Not (objScrewConicalFace Is Nothing) Then
                Marshal.ReleaseComObject(objScrewConicalFace)
                objScrewConicalFace = Nothing
            End If
            If Not (objGeometry Is Nothing) Then
                Marshal.ReleaseComObject(objGeometry)
                objGeometry = Nothing
            End If
            If Not (objFace Is Nothing) Then
                Marshal.ReleaseComObject(objFace)
                objFace = Nothing
            End If
            If Not (objFaces Is Nothing) Then
                Marshal.ReleaseComObject(objFaces)
                objFaces = Nothing
            End If
            If Not (objRevolvedCutout Is Nothing) Then
                Marshal.ReleaseComObject(objRevolvedCutout)
                objRevolvedCutout = Nothing
            End If
            If Not (objRevolvedCutouts Is Nothing) Then
                Marshal.ReleaseComObject(objRevolvedCutouts)
                objRevolvedCutouts = Nothing
            End If
            If Not (objRevolvedProtrusion Is Nothing) Then
                Marshal.ReleaseComObject(objRevolvedProtrusion)
                objRevolvedProtrusion = Nothing
            End If
            If Not (objRevolvedProtrusions Is Nothing) Then
                Marshal.ReleaseComObject(objRevolvedProtrusions)
                objRevolvedProtrusions = Nothing
            End If
            If Not (objModel Is Nothing) Then
                Marshal.ReleaseComObject(objModel)
                objModel = Nothing
            End If
            If Not (objModels Is Nothing) Then
                Marshal.ReleaseComObject(objModels)
                objModels = Nothing
            End If
            If Not (objPart Is Nothing) Then
                Marshal.ReleaseComObject(objPart)
                objPart = Nothing
            End If
            If Not (objOccurrence2 Is Nothing) Then
                Marshal.ReleaseComObject(objOccurrence2)
                objOccurrence2 = Nothing
            End If
            If Not (objOccurrence1 Is Nothing) Then
                Marshal.ReleaseComObject(objOccurrence1)
                objOccurrence1 = Nothing
            End If
            If Not (objOccurrences Is Nothing) Then
                Marshal.ReleaseComObject(objOccurrences)
                objOccurrences = Nothing
            End If
            If Not (objAssembly Is Nothing) Then
                Marshal.ReleaseComObject(objAssembly)
                objAssembly = Nothing
            End If
            If Not (objDocuments Is Nothing) Then
                Marshal.ReleaseComObject(objDocuments)
                objDocuments = Nothing
            End If
            If Not (objApplication Is Nothing) Then
                Marshal.ReleaseComObject(objApplication)
                objApplication = Nothing
            End If
        End Try
    End Sub
End Module
Posted by: mike drummond
Post date: 10/17/2008 5:08:17 AM
