simple circular Extrusion code
             I am learning solidedge programming and bit confused about contraining the profiles. Could any one post a simple code to model a fully contarined circular prostrution with its centre tied to origin?
Thanks & Regards
Noman Syed
Posted by: Noman Syed
Post date: 4/10/2008 2:20:34 AM
RE: simple circular Extrusion code
Noman,
Have you looked for an example in the SDKExamples.chm? It's located in the Solid Edge folder under the SDK folder. When you open the .chm, search for 'Protrusion'. I see several examples.
Posted by: Jason Newell
Post date: 4/16/2008 8:40:17 PM
Jason:
             Thanks for the information.
Naman Syed
Post date: 4/16/2008 10:26:13 PM
