sketch on assembly
Hi I have a problem
I need design a sketch on assembly file using geometry of a part that make assembly..
I try to active part but I can't use the edge line of a part to make my sketch I can't use the
hole center and so.....
I think it is possible.. can you help me?
Posted by: vito rufrano
Post date: 10/24/2007 6:50:15 AM
RE: sketch on assembly
Make sure to check "Peer Edge Locate" on your Main toolbar. This should give you what you are looking for.
Posted by: Bill Ledbetter
Post date: 10/24/2007 7:23:52 AM
