solid edge New Document customization
hi every one,
I want to modify some specification on openning a new document in SolidEdge like adding cutomized properties,customize background...
I'm adding this to my addin ..I keep searching for handler i get this SolidEdgeFramework.ISEApplicationEvents_AfterNewDocumentOpenEventHandler
but it seems not working.
Thank you
3 REPLIES 3
Re: solid edge New Document customization
Why don't you simply add the custom properties to your templates instead of looking for a software solution?
I don't have only one post running solid edge but more than 100 so i need to customize this..
so when any user wants to open a new file he gets the customized template..
What's the difference between installing your addin 100x or copying the templates 100x?
