trying to delete step assembly grounded relation
Hello there
I imported this assembly as a step file in solid edge . some how i couldnt delete the ground relation on its sub parts. could any one help to make it work?. Thanks
Re: trying to delete step assembly grounded relation
Edit or Open the sub assembly.
You can not delete something in a sub assembly from the higher assembly.
Sander
The Netherlands
Edit the subassembly with edit, then you can delete the relations
