use system library
As you can see part C build from system library which makes things fix, easy correct and contain another features refers to Part B that is a regular part.
The problem is that Part C affect only part B and not
part A because Part C and part B are in the same assembly and part A is in different assembly.
Question Is there any way that part C affects part A
(The idea is that all the add values (halls, cut outs) from system library (PART C) will put into part A).
maybe you have some macro supporting that issue.
Dear Mr/Mrs
I am asking your help with solid edge problem I am facing now
The device contain assembly of parts and assembly for ex the following schematic
Posted by: Mark Goldman
Post date: 4/4/2008 8:17:28 PM
