vb.NET --> Update active Draft's views?
Hi all,
I created a tool, which helps me to translate text in draft document to a different language. I use custom properties for the texts, which need to be translated and it works just fine... but after modifying the custom properties, I also need to update the views with "Update views"-button to update all the mapped values in the draft document.
How could it be done with vb.NET? I have tried following:
Sub UpdateViews()        Dim objApp As SolidEdgeFramework.Application = Nothing        Dim objDocuments As SolidEdgeFramework.Documents = Nothing        Dim objDraft As SolidEdgeDraft.DraftDocument = Nothing        Dim objModelLinks As SolidEdgeDraft.ModelLinks = Nothing        Dim objModelLink As SolidEdgeDraft.ModelLink = Nothing        Dim i As Integer        Try            objApp = Marshal.GetActiveObject("SolidEdge.Application")            objdocuments = objApp.Documents            objDraft = objApp.ActiveDocument            objModelLinks = objDraft.ModelLinks
            For i = 1 To objModelLinks.Count                objModelLink = objModelLinks.Item(i)                objModelLink.UpdateViews()            Next        Catch ex As Exception            Console.WriteLine(ex.Message)            MsgBox("Kuvantojen päivitys ei onnistunut.")        End Try
    End Sub
This does update the views, but it doesn't update the callouts if the content of the callout hasn't change. Could someone help me? Thanks.
Posted by: Janne Heinonen
Post date: 2/2/2012 8:23:50 AM
RE: vb.NET --> Update active Draft's views?
...and of course I solved it right after I posted this topic. Sorry about that, but here's the solution:
Sub UpdateViews()
Dim i As Integer
Try
Next
objDraft.UpdatePropertyTextDisplay()
End Try
End Sub
Post date: 2/2/2012 8:29:44 AM
