view orientation "Fit"
what is the method needed to fit my model to the part document window?
Bob Reinkemeyer
CAD Integration developer
Martin Sprocket and Gear Inc.
Re: view orientation "Fit"
sorry to bother everyone, I found the answer in an example on github
Application.StartCommand(SolidEdgeConstants.PartCommandConstants.PartViewFit);
Bob Reinkemeyer
Hi martyman,
better than calling a user command:
Find the ActiveWindow in the Application and use the View object ofthe Window and call Fit()
That should do the trick.
JB
SE ST10
