Сonformity fonts between AutoCAD and Solid Edge ST6
Good day dear colleagues!
I have some problem with mapping fonts from drawing .dwg from AutoCAD. In AutoCAD it's look like this:
In Solid Edge it's look like this:
There are all fonts in settigs "AutoCAD To Solid Edge Translation" on step 6, but sorting their conformity takes a lot of time:
Maybe anyone faced this problem before?
With gratitude for the cooperation,
Galiya Gabitova
Re: Сonformity fonts between AutoCAD and Solid Edge ST6
I see that your units for opening Autocad files are set to INCH and you have to change it to Milimeter to get the same Units like in your original files.
Yasser
Result:
Some dimensions had still duplicated...
