2 Point rectangle as default
Hi
I never use the center rectangle and I always am selecting it by mistake. Is there a way to make the 2 point
the default.
Also, I know one can do a hatch pattern but can you also fill with solid color.
I must admit older versions frustrated me. This new version is just wonderful.!!!!!!
PS. Don`t know if this is possible but smart sketch has a feature that you can pick from a list of previously
entered dimensions. Does Solid Edge have this functionality. It makes entering reoccurring values fast.
Regards Barry
Re: 2 Point rectangle as default
Hi
I did find the solid fill feature. I tried customizing the ribbon and removing the by center rectangle. That didn`t have any effect.
Esteemed Contributor
Hi there @bgolash,
For the Rectangle aspect....there is a handy function that may help you. Got to....Application button > Settings > Options, then on the "Helpers" tab, go to the Command Buttons group to check the box for "Last used command (in droplists) stays on top"
Then, for your solid color hatch fill......on the ribbon bar for the Hatch command, there is an option on there for it.
Solid Edge ST10 [MP6] Classic [x2 seats]
Hi Sean
I don`t think I`d ever have found that "use last command". That is valuable info for me.
Much appreciated.
BW barry
@bgolash Be aware that when you restart Solid Edge, the default command comes to the top again.
Production: ST10 MP5
Testing: SE 2019
Hi Ken [@KennyG],
I'm actually seeing this "switch" persist between Soid Edge restarts.
I'll have to check on that.  Wasn't supposed to...
Testing: SE 2019
...further, it even persists after a full system reboot.
