2d-solid-edge refuses to save changes of a drawing
Not applicable
I like 2d-solid-edge very much. I use it mainly to get geometric data from drawings.
Therefore I insert a jpeg-file into my drawing and stretch it to scale 1:1. Then
I easily gain the geomtric data (I often use the geoemtric data for static design
in RStab). Easy static-calculations can be done directly in 2d-solid-edge (triangles
of forces, reaction forces of single-span-girders and so on).
However sometimes I have a problem with saving my drawings. Then 2d-solid-edge refuses
to save changes of my drawing. Does anybody know what could be the reason for this
misbehavior?
Re: 2d-solid-edge refuses to save changes of a drawing
Not applicable
Hermann,
Without more detail, it is difficult to determine why this is happening. How
often does it happen? Is it always the same workflow when this happens? If
you can provide an example and a workflow to reproduce the problem, we can
take a look.
Rick B.
Not applicable
Just a guess here, but is it Vista you are using?
I've seen a problem whilst saving a template in Vista, which sounds like it was
similar to what you were experiencing.
The exact nature of my issue occurred when trying to overwrite an existing file
in SE2D (V20) in Vista.
I've not seen this problem in XP, so I'm guessing it might be something to do with
the Windows Rights settings.
-Andy.
>drawings.
>Then
>design
>(triangles
>refuses
>for this
>misbehavior?
www.continual-motion.com
Not applicable
>drawings.
>Then
>design
>(triangles
>refuses
>for this
>misbehavior?
