3D Sketch connect
Hi~ Edgeusers
As shown in the attached figure, the 3d sketch function
I want to extend it ..
But I want to match 3d sketch lines and holes ... (like connect constraint)
What should I do ...?
How to contact us.
file Attach
Re: 3D Sketch connect
Matt Johnson
SE2019 Pre-Production Testing
Teamcenter 10.1.7
You also have to have Peers turned on?
Thankyou~ matt
