64 bit version solid edge
N/A
my desktop doesn't support solid part and sheet metal part.
the program stop responding as i click on solid part or sheet metal parts and compatibilty mode didn't help.
desktop runs on 64 bit windows 7 ultimate.
is there any where i can download 64bit version of solid edge?
Re: 64 bit version solid edge
N/A
There is not a 64 bit Student Edition available. Win 7 64 will run the
32 bit version of SE correctly. I would suggest you remove and
reinstall doing the following:
* Deactivate your virus scanner before the install. Reactivate after
the install is finished.
* Turn off User Account Control before installing. You can turn it on
after if you wish (setup licensing before turning it back on).
* Right Mouse Click on the Setup.exe and choose "Run as administrator".
http://grundey.blogspot.com
http://www.pella.com
