A couple of dialog box issues
These have been going on for several service packs, although I cannot pinpoint which ones or when specifically they started except that they started at different times so I don't think they are related; now that I have a few minutes I thought I'd ask the collective if they have encountered these and if they know of a fix. I'm using Win7, ST8 MP08
Issue 1. Error dialog is MIA
The errors dialog is nowhere to be found when the "errors" button is clicked; it stays selected as if it's working properly, I'm wondering if its off-screen somewhere?
Issue 2: The Insert Part Copy dialog is undersized, I cannot click-n-drag the edges to resize it, any ideas?
Any advice would be greatly appreciated, Thank you.
Re: A couple of dialog box issues
Have you tried adjusting your DPI settings?
If not a DPI or resolution adjustment, you can find programs online that allow you to resize unresizable windows.
Solid Edge 2019
Windows 7 Professional
Nvidia K2200 & Intel Xeon
"You're doing it wrong"
I tried to change the DPI, but no luck; I didn't think this would be the issue because its only the one dialog that is undersized and it seemed that a DPI change would affect everything. I found a window resizing utility that did the trick; thank you for that suggestion.
My "errors" dialog was indeed opening off screen and it was a simple procedure to return it to our plane of existence.
Thank you for your time.
